  • djgrimshaw Friend
    #123901
    This is a really great template. However, I have found that the main menu and top menu display the same text. How can I change the top menu? I have tried editing the menu module but haven’t found a solution.
    Would really apprectiate some help.
    Menalto Friend
    #233140
    Open up the template folder and there you see ex ja_transmenu.php, open up the menu you use and change this(marked in red) to the menu you wanna have at top.:
    $japarams->set( 'menutype', 'mainmenu' ); // Source of menu
    djgrimshaw Friend
    #233148
    Thanks for your reply. I have searched my site and not found the file: exja_transmenu.php
    Could you send it to me?
    Menalto Friend
    #233149
    <em>@djgrimshaw 32505 wrote:</em><blockquote>Thanks for your reply. I have searched my site and not found the file: exja_transmenu.php
    Could you send it to me?</blockquote>
    It’s ja_transmenu.php and its in the templates folder.
    NOTE: i just took ja_transmenu.php as an example, you need to do the changes in the menu system you are using.
This topic contains 4 replies, has 2 voices, and was last updated by  Menalto 17 years, 1 month ago.
