  • iculture Friend
    #124107
    hello, i’m very new in joomla so please be patient.
    i just installed this template but it has some error and top menu doesn’t look proper. can you check it please and tell me how to correct it?
    http://www.ikultura.net/j3
    second thing is that when i was trying to place newsflash following tips on this forum i cannot find places where for example write width of newsflash module…
    anyway, menu subject is the most important for me. i will be very thankful for help
    cssyeah Moderator
    #233758
    Hi iculture,
    I think the top menu appear right, but now you can say with me, how do it (the top menu) appear?, and if you don’t want to show the title of module, you need add Module class surfix is -notitle (Ex: Module Other menu on your site.)
    mfcphil Friend
    #233760
    Top menu looks very dodgy and the header image isn’t all showing…if it were me I would re-install the template!!
    Your header image is ok on other pages??
This topic contains 3 replies, has 3 voices, and was last updated by  mfcphil 17 years, 1 month ago.
