  • Dean Howarth Friend
    #170522
    Hi I have just enabled Top_Panel which shows, although is it supposed to slide down ?
    Please Help
    http://www.c2conline.com.au
    Appreciate your advise
    khoand Friend
    #423844
    What do you want to change? A snapshot with your annotation is very helpful to illustrate your problem.
    Dean Howarth Friend
    #423894
    Please see image below
    1. 2011-11-10_0734
    kobenes Friend
    #423991
    Did you install and use JA Top Panel Module for this position?
    Dean Howarth Friend
    #424011
    Thanks I have now, but still loks awful?, any idea why? also is there anyway to rename it to say something like “Support”
    Thanks for your thoughts
    khoand Friend
    #424054
    Thank you, kobenes.
    You remove code from /template/ja_droid/css/template.css
    #ja-top-panel {
    z-index: 16;
    position: relative;
    top: 30px;
    #ja-top-panel .main-inner1 {
    border: 2px dotted #E2E2B5;
    padding: 5px 10px;
    text-align: center;
    margin-top: 15px;
    background: #FFC;
    .bg-transparent {
    background: url(../images/trans-topcpanel.png);
    Dean Howarth Friend
    #424158
    Hey All thank you for your help. One minor problem now.
    It doesnt work with Internet Explorer ( cant click on the button?)
    Appreciate any thoughts
    khoand Friend
    #424244
    I tested your website by IE8. It works normally. What version of IE do you use?
This topic contains 8 replies, has 3 voices, and was last updated by  khoand 13 years ago.
