schuller Friend
schuller
- November 2009
December 7, 2011 at 11:33 am #171554Dear
i would like to know how i translate the name of button READ MORE and the name SETTINGS in each categories in front page?
The official language is Portuguese and i did translate but this 02 things notยดs possible.My website: http://www.bombounanet.com.br
I AM WAITING 1 MONTH FOR HELP
I hope help
Best regards
pavit Moderatorpavit
December 7, 2011 at 11:40 am #428403Hi schuller
You are referring to the Ja_News_Pro Module ?
December 7, 2011 at 12:07 pm #428415You can change the word SETTING in this file
modulesmod_janewsprotmpldefaultblog_usersetting.php around line 32 now you have
[PHP]<a class=”ja-usersetting-loadform” href=”javascript:void(0)” onclick=”return janewspro.showForm( $(‘ja-usersetting-item-<?php echo $id?>’))” id=”ja-usersetting-loadform-<?php echo $id?>”>
<span><?php echo JText::_(‘SETTING’)?></span>[/PHP]Change the word SETTING
For the READ MORE you can change the value of COM_CONTENT_READ_MORE in file
language/en-GB/en-GB.com_content.ini
jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
December 7, 2011 at 12:22 pm #428419<em>@pavit 287570 wrote:</em><blockquote>You can change the word SETTING in this file
language/en-GB/en-GB.com_content.ini</blockquote>
@pavit
If we already have JText::_(‘SETTING’) here it’s mean we can apply translate language for this. So don’t need change hard code
Check into ( if not exist than just create it )
/language/en-GB/en-GB.mod_janewspro.ini
and insert
SETTING=<your string>
Thank you,
1 user says Thank You to jooservices for this useful post
schuller Friendschuller
- November 2009
December 8, 2011 at 3:23 am #428576Hi dear
Thanks for you reply. I did the change word SETTING, but not was possible the change READ MORE.
Look the pic
- October 2014
- November 2009
December 8, 2011 at 11:48 am #428681jooservices Friendjooservices
- October 2014
- November 2009
December 9, 2011 at 6:10 am #428892Dear
I sent a private message with login and password FTP
Schuller
- October 2014
December 9, 2011 at 7:48 am #428900Hi
I have updated your site
Language file:
/www/bombou/language/en-GB/en-GB.mod_janews_featured.ini
I have added
READ_MORE...="Read more... translated"
Please translate it as you need. And do same for another language.
Thank you,
ps:// your site have some modules a bit old. please upgrade.1 user says Thank You to jooservices for this useful post
- November 2009
December 11, 2011 at 6:04 am #429184Dear
Thanks for all.
Tell me whitch modules are old and how i do upgrade?
- October 2014
December 12, 2011 at 3:10 am #429244<em>@schuller 288523 wrote:</em><blockquote>Dear
Thanks for all.
Thanks</blockquote>
At moment i don’t remember much.
But you can check your installed extensions ( not only modules but also any extensions installed ) and compare w/ latest version from author site ๐
Tha’ts one of step for site maintenance ๐Thank you
AuthorPostsViewing 12 posts - 1 through 12 (of 12 total)This topic contains 12 replies, has 3 voices, and was last updated by jooservices 13 years ago.
