  • rooky Friend
    #118838
    This is my testing site:
    http://www.genitalechirurgie.nl/index.php (dutch)
    If you open it in IE (v7) and you look at the main menu, you see a button OPERATIES.
    If you go over it, the menu drops down and you can select 1 of the 4 items.
    When this page opens, you can see the small menu blocks appearing on the right side.
    But if you open in FF (1.5.0.9) and you go to that same dropdown menu… you can see the 4 items.
    If you click on one of the 4 items, the page will open, but NOT the menu blocks on the right side.
    The blocks WILL open, if you only click on the button OPERATIES and not on one of the dropdown items.
    I have looked for a solution, but didn’t find it.
    Hopefully you can be of help
    thnx
    appaloosa Friend
    #216949
    How you did same orange background in contentheading as in componentheading ?
    Anyone can help me with this ? :confused:
This topic contains 2 replies, has 2 voices, and was last updated by  appaloosa 17 years, 9 months ago.
