  • anto33 Friend
    #120233
    Hello everybody,
    I’ve installed transmenu on my local test website and I’ve no problem with firefox but with IE, my transmenu which is horizontal causes problem because its submenus goes under my left vertical menu.
    As i don’t know if anybody can understand this explaination, i put some pictures so that you can understand the problem (to me it’s a problem with z-index but I don’t know which):
    Under firefox:
    under IE:
    If someone can help me to fix this problem..
    thanks.
    ifreefly Friend
    #220635
    mine does the same thing though does it in firefox as well… can someone please help us?
    bigrk Friend
    #220639
    anto33, You should PM one of the moderators and pose your question to them if you are still having problems or open a new thread in the associated template forum. 😎
    brandon12 Friend
    #220644
    If you have live site, i will help you easier. You can find in template_css.css #mainnavwrap
    Add properties: z-index:10;
    bigrk Friend
    #220656
    <em>@oceandragon 16225 wrote:</em><blockquote>If you have live site, i will help you easier. You can find in template_css.css #mainnavwrap
    Add properties: z-index:10;</blockquote>
    Thanks! This is a good resolution to know. 🙂
    anto33 Friend
    #220832
    sorry to be late to answer.
    I tried your method but i’ve no #mainnavwrap in my template_css.css
    I’m using the template madeyourweb
    If it could help you to find the solution…
    Unfortunatly i’ve no live site, it is local but I can put my css if you want ??
    Thanks a lot 🙂 .
This topic contains 6 replies, has 4 voices, and was last updated by  anto33 17 years, 6 months ago.
