  • adnanpirota Friend
    #158462
    When I activate typo plugin in my admin area my site becomes like attached photo. Any idea anyone?
    1. typo-error
    walkysss Friend
    #370866
    I got the same issue as well but if you uninstall the plugin it will go back to normal …that issue was going to be my next one ..
    adnanpirota Friend
    #370878
    Sorry walkysss but that does not solve my problem, I have unpublished the plugin and the page is OK but I really want to use it so I excpect any of JA developers to answer this one …
    Phill Moderator
    #370880
    I have created a bug report for you. There seems to be an issue which hopefully the developers can look into soon.
    adnanpirota Friend
    #370952
    I do not know how exactly I managed to download this plugin before but now when I try to download it the system is telling me that I am not member of extensions club or something like that and this plugin is not included in templace pack so what is going on can anyone tell me ?
    Phill Moderator
    #370955
    I believe the plugin was accidentally included in the templates download but in fact it is there for JAEC and Developer members. You will almost certainly find it in the download when you first got your template.
    adnanpirota Friend
    #370965
    But as far as I understood from the readings I have done, typography in Teline IV is comming from T3 framework so how am I going to see (or use) typography if I am not entitled to use button ?
    Phill Moderator
    #370969
    You can simply add it in the same way we used to before this plugin appeared.
This topic contains 8 replies, has 3 voices, and was last updated by  Phill 13 years, 11 months ago.
