  • fdr77 Friend
    #169213
    when I upgrade to jat3 1.3.0 the drop-down menu does not work
    Why??
    TomC Moderator
    #416307
    Were you previously working with the J1.5 version of Teline IV?
    fdr77 Friend
    #416414
    teline iv 1.2.5 and jat3 1.2.6 work fine… by jat3 1.2.7 creates problems
    TomC Moderator
    #416474
    <em>@fdr77 272235 wrote:</em><blockquote>when I upgrade to jat3 1.3.0 the drop-down menu does not work
    Why??</blockquote>
    Which “drop-down” menu are you referring to? When I looked at your site just now, the mega-menu drop downs appear to be functioning correctly.
    fdr77 Friend
    #416528
    I’have downgrade to 1.2.6..if you have time to see I re-upgrade to the 1.3.0
    fdr77 Friend
    #416838
    Can anyone give me some help?
    fdr77 Friend
    #417510
    Solved. It was a conflict with the animations of the mega menu(fade,slide,slide and fade).
    I set to none animations and work fine.Thank you
This topic contains 7 replies, has 2 voices, and was last updated by  fdr77 13 years, 2 months ago.
