  • baingao191 Friend
    #189486
    Hello, I just enabled the url rewrite in my site http://softhive.net/wall/ but then every article give this message :
    Not Found
    The requested URL /wall/78-hi-tech/108-racial-spencer-desperate was not found on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
    ps. : I had mod_rewrite enabled, and my other sites on the same server works well with url rewrite
    what went wrong?
    please help.
    Thank you
    Nazario A Friend
    #501450
    Hi baingao191,
    I can’t access your FTP (http://prntscr.com/1jtuxu).
    You can send me the correct one via PM, then I will try to check for you.
    Look forward from you.
    Regards,
    Nazario
This topic contains 2 replies, has 2 voices, and was last updated by  Nazario A 11 years, 4 months ago.
