fcweb Friend
fcweb
- June 2014
March 12, 2015 at 8:41 am #562769ok thanks,
look when i click on the video on the first page , a popup page is loaded , and embedded video superposed to be loaded at the center of the pop up page , but it is not!
i mean instead of playing video inside the page , windows media player start to play the embedded video outside the page !
that’s the problem. as you could see in :http://i61.tinypic.com/2iurwgg.jpg
also i attached the photo shows IE properties.
thanks
jooservices Friend
jooservices
- October 2014
- 1245 times in 1121 posts
March 12, 2015 at 8:47 am #562774Hi there
ola . Finally i can understand. And …. sorry 🙁 It’s managed by OS / Browser. Except you have your own player to handle that.
You are using HTML 5 <video> … so not much we can do.
You can check around for better player and use that on your site.Thank you,
Viet Vufcweb Friend
fcweb
- June 2014
March 12, 2015 at 8:54 am #562776sorry but I don’t get you!
would you please explain it . :((
i mean what should I do?
would it be right if I changed the video format to .fla (flash) ?jooservices Friend
jooservices
- October 2014
March 12, 2015 at 9:09 am #562782Hi there
There are few plugin on JED can help you do that.
Do instead of use mp4 on your hosting, you can upload it on youtube and use embed code on your site.Thank you,
Viet Vifcweb Friend
fcweb
- June 2014
March 12, 2015 at 9:24 am #562783ok thanks ,
I understand that there is no fixed solution , so I have to change the file extension to see the result .
BTW , I cant use youtube because it is filtered here and the problem becomes worse. 🙂please let me know some of plugin’s name that might help me .
thanks for all answers and comments.
jooservices Friend
jooservices
- October 2014
March 12, 2015 at 9:39 am #562787Hi there
# At first i think it’s only issue if client side configured to catch video file.
# You can check this one
http://www.joomlaworks.net/extensions/free/allvideos
Thank you,
Viet VuAuthorPostsThis topic contains 21 replies, has 3 voices, and was last updated by
jooservices 9 years, 10 months ago.
