  • goranm Friend
    #186265
    1. How can we solve the problem – if it is one, because i don’t see a way to implement Youtube-Videos – that Youtube Videos don’t fit in Mobil-View?
    I tried to implement one via HTML code from YouTube, could not see anything, just white space in the ARTICLE. I guess, if it works, the video would stay the same hight and weight…
    Does anybody have an idea?
    2. Is there a way to tell the Template to show small mobile-adsense-banners just in mobile-view, instead of the big ones?
    Regards and thanx
    Manos Moderator
    #488052
    Did you check after saving the article the the code was still there ? Editors have the tendency to strip html code unless you configure them the other way.
    Manos
    goranm Friend
    #488062
    yes, the code is there… looked at source code with firefox… its there a video in a template-article?
    Manos Moderator
    #488064
    Can you please provide a link where i can see that also ? maybe you miss something who knows 🙂
    Manos
    goranm Friend
    #488066
    Sent it to your inbox!
    Manos Moderator
    #488069
    I am going to need access to your Joomla backend so i can investigate this further.
    Manos
    goranm Friend
    #488071
    inbox ! 🙂
    goranm Friend
    #488074
    Yeaaaaaaaaah!!!!! 😀
    What was the problem????
    Manos Moderator
    #488075
    You are using a wrong version for the embed code from youtube, also after some googling looks like some people have managed to make it work in responsive layout, i haven’t search the issue thorough but you might be able to achieve that fairly easy 🙂
    So check the code i have embed on your website and google responsive youtube and you will come up with some good solutions!
    Manos
    Manos Moderator
    #488076
    goranm Friend
    #488077
    OMG, there seems to be a solution for the “Responsive-Video” problem cool!
    Oh oh… i inserted the YT-Code again:
    <object width=”560″ height=”315″><param name=”movie” value=”http://www.youtube.com/v/A9p_6_Xy7T4?hl=de_DE&version=3″></param><param name=”allowFullScreen” value=”true”></param><param name=”allowscriptaccess” value=”always”></param><embed src=”http://www.youtube.com/v/A9p_6_Xy7T4?hl=de_DE&version=3″ type=”application/x-shockwave-flash” width=”560″ height=”315″ allowscriptaccess=”always” allowfullscreen=”true”></embed></object>
    The Video is not there 🙁
    When i opened the article again, i just found this code inside:
    <p><object width=”560″ height=”315″><param name=”movie” value=”http://www.youtube.com/v/A9p_6_Xy7T4?hl=de_DE&version=3″ /><param name=”allowFullScreen” value=”true” /><param name=”allowscriptaccess” value=”always” /></object></p>
    Manos Moderator
    #488078
    Hi, this code is not the right code! If you want to insert the video i suggest that you turn your editor off, paste the code and then save the article with the editor to off .
    Manos
    goranm Friend
    #488080
    First code is right
    Second, shorter one, is wrong
    Ok?
    I can see that the editor is doing something to the code.
    I clicked “toggle editor” but couldn’t figure out how to save without getting the editor on before it saves???
    Manos Moderator
    #488081
    I just configured your editor to “Extended” so give it one more try, maybe it’s better if you install JCE you will have better luck when editing and inserting video within your articles! Also with JCE you can have additional plugins that help you insert a video from many video providers.!
    Manos
    goranm Friend
    #488082
    Hey Thank you this is my old editor on my joomla 1.5 site 😀
    OMG THANK YOU… never in my life i could have suggested that this problem could be lay on editor-functionality 😀 THANK YOU S OMUCH!!!!!
    I have the next big challenge for you in my new thread ;D
This topic contains 15 replies, has 2 voices, and was last updated by  goranm 11 years, 8 months ago.
