Phan Gam Friend
Phan Gam
- June 2008
- 39 times in 38 posts
December 21, 2010 at 7:39 am #367892Hi there,
I download quickstart and trid to find the issues. But i do not see the problems you are facing.Its best to get your site online and then we can have a look and try to help you out. Its very difficult right now to guess.
steinar Friend
steinar
- July 2007
- 98 times in 84 posts
December 21, 2010 at 9:38 am #367915<em>@tosa23 209873 wrote:</em><blockquote>Anyone? Please!</blockquote>
Have you checked the tip from mmckeen in post no. 4? I think you’ll find that the Hide Main content block in Home profile is set to Yes.
December 21, 2010 at 4:52 pm #367976<em>@steinar 209990 wrote:</em><blockquote>Have you checked the tip from mmckeen in post no. 4? I think you’ll find that the Hide Main content block in Home profile is set to Yes.</blockquote>
I didn’t try that, can you specify details? Where set that?
steinar Friend
steinar
- July 2007
December 21, 2010 at 5:24 pm #367981<em>@tosa23 210060 wrote:</em><blockquote>I didn’t try that, can you specify details? Where set that?</blockquote>
Extensions > Template manager > Teline IV > Profiles : Home : Global settings : Hide Main content block.
Switch from Yes to No.
As you may have seen, new versions of some of the central parts of Teline IV were published today. But I think this value is set to «Yes» even in the new version.
Good luck!
December 21, 2010 at 6:57 pm #367987<em>@steinar 210066 wrote:</em><blockquote>Extensions > Template manager > Teline IV > Profiles : Home : Global settings : Hide Main content block.
Good luck!</blockquote>
I can’t believe. By default is that value “No”. I just installed new version. Problem is still here. I don’t understand, wtf is this. Blah… What else can I try? That’s really… ermm…
EDIT: I think I found problem. Problem is in Firefox version 3.6.13.
In Safari works. But, can anybody fix that?steinar Friend
steinar
- July 2007
December 21, 2010 at 8:43 pm #367996<em>@tosa23 210080 wrote:</em><blockquote>I can’t believe. By default is that value “No”. I just installed new version. Problem is still here. I don’t understand, wtf is this. Blah… What else can I try? That’s really… ermm…
In Safari works. But, can anybody fix that?</blockquote>That’s strange. I presume you have emptied the caches, both under administrator > tools and in your browsers?
You see, I had the same problem as you have described at least since version 1.1.0, without discovering it until yesterday :-[But after switching the Hide main content block setting, all seems to work as expected. In my case the culprit was in the Home profile setting, but it might be worth checking all the profiles.
If things works in Safari, they are usually adhering to standards. But that isn’t good enough if your settings don’t also work in Internet Explorer. I just checked the last 10.000 visits at my site: No less than 66,1% used IE; 12,7% FF for Windows, 4,2% Chrome for Windows and 3% Opera for Windows. That is 86 percent Windows users. The infamous IE6 has less than 10 percentage points of those, but is still larger than Safari’s 9 percent.
December 21, 2010 at 9:14 pm #368001<em>@steinar 210093 wrote:</em><blockquote>That’s strange. I presume you have emptied the caches, both under administrator > tools and in your browsers?
If things works in Safari, they are usually adhering to standards. But that isn’t good enough if your settings don’t also work in Internet Explorer. I just checked the last 10.000 visits at my site: No less than 66,1% used IE; 12,7% FF for Windows, 4,2% Chrome for Windows and 3% Opera for Windows. That is 86 percent Windows users. The infamous IE6 has less than 10 percentage points of those, but is still larger than Safari’s 9 percent.</blockquote>
Omg, I did things wrong.
I didn’t set ‘No’ i ‘Home profile’, I just looked at ‘Default profile’ -> there was no by default, but in Home wasn’t. Now I set up
‘No’ in ‘Home profile’ and it works 🙂Thanks everybody, I really excuse for my ‘not doing things right’ 🙂
Best Regards to all!EDIT: steinar, if I understand you what you want to say -> I wrote before ‘can anyone fix that?’ becouse I want to my templates works on all web browsers 🙂 So, now is problem solved and all is fine 🙂
Phill Moderator
Phill
- February 2014
- 2206 times in 1818 posts
December 21, 2010 at 9:15 pm #368003I agree with steinar here, it is probably the cache on firefox. If it works in Safari then it is unlikely to be the caches in the Joomla back end. Try using <cttrl>+F5 while viewing your page in FF and see if that clears it. Some items with profiles are also stored in cookies so you may have to clear your cookies in FF too.
steinar Friend
steinar
- July 2007
December 21, 2010 at 9:29 pm #368007<em>@tosa23 210099 wrote:</em><blockquote>So, now is problem solved and all is fine :)</blockquote>
Wow, that’s great! And if I may be so free: You should really go to http://www.joomlart.com/forums/topic/problem-with-viewing-articles/#post-367226 and press mmckeen’s Thanks button. After all he presented the correct solution already last week 😀
Ciao!December 21, 2010 at 10:09 pm #368013<em>@steinar 210106 wrote:</em><blockquote>Wow, that’s great! And if I may be so free: You should really go to http://www.joomlart.com/forums/topic/problem-with-viewing-articles/#post-367226 and press mmckeen’s Thanks button. After all he presented the correct solution already last week 😀
Ciao!</blockquote>I give “thanks” to him now 🙂 Yes, his answer was correct, but I wasn’t enough smart 🙂 Cya 🙂
This topic contains 25 replies, has 9 voices, and was last updated by tosa23 14 years, 1 month ago.
