June 22, 2012 at 4:33 pm #178432
virtuemart does not work with this template, even in your demo the cart is not updated, there is not the price of products if you try to purchase: anyone can help me?
Thanks 🙂Stork11 FriendStork11
- March 2011
- 431 times in 393 posts
June 23, 2012 at 7:01 am #458572<em>@filomena78 326821 wrote:</em><blockquote>Hi,
Thanks :)</blockquote>
Hello filomena78,Please check if your browser enables to accept cookie or not. Your browser must enable to accept cookie so that you can update your shopping cart.
Regards.
July 23, 2012 at 2:56 pm #461929I have the same problem, if i change template everything works fine with virtuemart.
juliaroder Friendjuliaroder
- January 2012
July 24, 2012 at 8:35 pm #462083i have the same problem, searched in the forum and found some template update issues, but the problem doesnt dispear by deleting the cart folder from components/virtuemart/ html…
also checked javascript and css set to no…
please helpalemao59 Friendalemao59
- August 2010
- 2 times in 1 posts
August 11, 2012 at 6:12 am #463911I have the same problems too. Prices are not shown when you go to the shopping card or trying to checkout. Even on your demo site it doesnt work.
- March 2011
August 16, 2012 at 10:34 am #464415Hello all,
I find that cache caused this problem. You can exclude cache for “VM Shopping cart” module position. In this case, the position is “right”. So you can add “position=right” in “Cache Exclude” of “Template manager”.
Hope this help.
Regards.
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 5 voices, and was last updated by Stork11 12 years, 1 month ago.
Problem with Virtuemart
