April 24, 2015 at 4:59 am #205791
jooservices Friend
jooservices
- October 2014
- 1245 times in 1121 posts
April 24, 2015 at 5:19 am #568145Hi there
Please turn on display_errors .Thank you,
Viet Vujooservices Friend
jooservices
- October 2014
April 24, 2015 at 5:19 am #733251Hi there
Viet VuApril 24, 2015 at 5:46 am #568148display_errors now is turn on
April 24, 2015 at 5:46 am #733254display_errors now is turn on
jooservices Friend
jooservices
- October 2014
April 24, 2015 at 6:05 am #568149Hi there
For next time please also turn on display_error in Joomla! ConfigurationAt moment we know what’s wrong
Strict Standards: Declaration of plgVmPaymentFlow::emptyCart() should be compatible with vmPSPlugin::emptyCart($session_id = NULL, $order_number = NULL) in /home/tuetue/public_html/plugins/vmpayment/flow/flow.php on line 577
CartContinue Shopping
Fatal error: Call to undefined method shopFunctionsF::getComUserOption() in /home/tuetue/public_html/templates/ja_mixmaz/html/com_virtuemart/user/login.php on line 30
Please try to rename that override layout. Or provide FTP access i’ll help you inspect that .
Thank you,
jooservices
- October 2014
April 24, 2015 at 6:05 am #733255Hi there
Thank you,
Viet VuApril 24, 2015 at 8:04 am #568182i send the ftp’s data via private message
April 24, 2015 at 8:04 am #733278i send the ftp’s data via private message
jooservices Friend
jooservices
- October 2014
April 25, 2015 at 1:44 am #568259Hi there
I’m working on it for now.
Thank you,
jooservices
- October 2014
April 25, 2015 at 2:09 am #568261Hi there
I have fixed for above issue.
But please consider you are using VM version which one is not supported yet in this template.
Thank you,
Viet Vu -
This topic contains 11 replies, has 2 voices, and was last updated by sebastiangaticacl 9 years, 9 months ago.
