mandig Friend
mandig
- October 2010
- 2 times in 1 posts
April 19, 2012 at 9:25 am #176282Hi,
I have a simple but bad problem with VM Categories module pagination. I attached an image that shows better than words what I mean but basically the problem is that even changing the parameters in the backend the module shows only 1 item per line.
I’m not able to find the code line handling this problem but I really can’t keep it like this because it is really not so nice to see.
Thanks for any kind of help you could provide me.
Saguaros ModeratorSaguaros
April 21, 2012 at 3:48 am #449428Hi mandig,
In Virtuemart component > Configuration > Configuration > Templates.
You can set number of products or categories per row. Save and Clean all the cache.Hope this helps.
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by Saguaros 12 years, 5 months ago.
Problem with Virtuemart Categories module
