  • Tech-xml Friend
    #158068
    Componet installed VirtueMart.
    The system does not work with AJAX button: ADD CART
    I tested this on other JA templates and got the same problem.
    How to solve this?
    Ps. Would not want to disable this option, I need this functionality.
    Tech-xml Friend
    #369620
    Can anyone help me solve this problem.
    How to operate the button CART AJAX in VirtueMart JA Templete
    Tech-xml Friend
    #369838
    problem solved
    Noemi Peli Friend
    #371644
    I am having exactly the same problem, how did you solve this?
This topic contains 4 replies, has 2 voices, and was last updated by  Noemi Peli 14 years ago.
