vvvvvvvvvvvvv Friend
vvvvvvvvvvvvv
- May 2017
June 9, 2017 at 5:29 am #1040892Hello, I am very grateful for the help they provide because they have helped me a lot, my current problem is when I drag or write the address of the website in my facebook status, this generates information from the template and not from my client, telling me that I needed a solution Quick, started looking for and found someone in the same situation, the problem was in the metadata section of the main menu main button, then change everything, I put information of my client, but I have 2 days waiting to see if it is a problem Proxy, cache or something that is not updated, but almost on the third day still this generates the same problem, I wanted to know if they can help me solve it, I attached an image with the problem so that they can have a better problem and wait His kind help.
This is the message: Joomla template for alumni and university – JA Alumni built with T3 Framework, fully responsive and integrates JA page Builder
- This topic was modified 7 years, 6 months ago by vvvvvvvvvvvvv.
June 11, 2017 at 1:55 am #1041105Hi
Kindly open Menu > Main Menu > Home > Metadata > change the meta description and keywords.
Also, open the Page display tab and add your browser page title.
save and checkRegards
vvvvvvvvvvvvv Friendvvvvvvvvvvvvv
- May 2017
June 12, 2017 at 11:56 pm #1041393I already updated the metadata information, according to your indications, although I had already done it, clean the cache in joomla, I do not know what else to do, my client tells me what kind of website I did that puts information from others? And I do not know what to answer, I download the .sql and check using notepad ++, I did not find anything, then I downloaded the website and search with fileseek and I did not find anything, can you help me with some other idea?
June 13, 2017 at 2:22 am #1041431Hi Can u share the URL of site here?
- This reply was modified 7 years, 6 months ago by Pankaj Sharma.
- May 2017
June 13, 2017 at 5:35 pm #1041655Sure!
carrestorationdetailercr.com
And thanks again!
June 14, 2017 at 1:33 am #1041701Hi
Can u check it again? I just scrapped the data from Facebook debug tools and its showing fine http://prntscr.com/fjhohfRegards
- May 2017
June 15, 2017 at 2:48 am #1041953Mr. Pankaj, really thanks, you are really a very kind and efficient person, I hope you value your effort and dedication in your company, because I know that is not something common these days, I reiterate my thanks! I just wanted to ask you in the most humble way to show me how to do it, I would not want to disturb anyone else because of an equal problem in the future, it would be the last thing to close this post.
Greetings from Costa Rica!
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 7 replies, has 2 voices, and was last updated by Pankaj Sharma 7 years, 6 months ago.
Problem with website info and facebook
