  • andreamarucci Friend
    #171735
    I’ve a problem with this template and Widgetkit only with IE9. If you visit this page
    http://www.lumitel.it/joomla/index.php?option=com_content&view=article&id=78
    with IE9 you’ll see that all the images are shown as a little row but if you visit them with FF or other browsers everything is ok. I don’t think it’s a problem of widgetkit since on other site it work perfectly so maybe is an interaction between Widgetkit and this theme.
    Can you help?
    jooservices Friend
    #429425
    That WidgetKit ( YOOtheme ) issue.
    Because height of image they are using “auto” instead correct value. And that make trouble on IE.
    You can ask them to fix it.
    Thank you
This topic contains 2 replies, has 2 voices, and was last updated by  jooservices 13 years, 1 month ago.
