November 8, 2011 at 2:05 am #170481
Hi!
I have an issue with z-index.
It works well only on webkit based browsers (like chrome & safari) but not with IE 9, FF 7 and Opera 11.
eg. part of main body has to be over topsl position (for 20px) and it shows good on webkit browsers with z-index value 5. On other browsers it does not work at all. (z-index has the same values like on blank t3 template)
any suggestions?
EDIT: all positioning has the same value as on blank t3 template.
Manos ModeratorManos
- February 2014
- 633 times in 576 posts
November 8, 2011 at 2:43 am #423622Hi,
Can you please show us your website ? I am pretty sure that it’s working very well on IE 9 and FireFox and Opera, so my guessing is that there is an other issue that causes this particular problem.Regards
1 user says Thank You to Manos for this useful post
November 8, 2011 at 2:57 am #423623Need to upload template. Fixed some issues with using position:absolute but i’ll upload template without those fixes just to show you where was the problem. I still think that fixing the issue with position:absolute isn’t the best thing so any suggestions would be welcome.
I need to put some menues, and text so that you can see whats gonin on 🙂
EDIT: Uploaded. Will be available for an hour or two for public.
November 8, 2011 at 3:23 am #423629Do you see the difference between showing on webkit and other browsers. On IE9 and FF the problem is the same, and on Opera it works ok with overlaying main over showcase position but the problem still persist on menu and showcase.
Any suggestions how to solve this problem?
EDIT: solved problem, thanks anyway.
.wrap { width: 100%; clear: both; } in layout.css was making some problems, other problems were solved as previously explained.
- February 2014
November 8, 2011 at 4:04 am #423631Hi,
I didn’t even managed to see that problem :laugh: but anyway i am glad that you found the solution even if i wasn’t much of a help here!
Manos
P.S. I can still see some differences on Opera and Safari on the space that’s under the main picture you have.
This topic contains 6 replies, has 2 voices, and was last updated by trancehr 13 years, 2 months ago.
