  • tonkatonka Friend
    #174859
    All
    My site is http://www.countryalliance.org
    If you go to the front page, you’ll see I’ve got a banner there. I can see it on that page, but not the others – even though I can see it using Firebug.
    It’s hidden behind the flash header – but why? Is it a z-index value somewhere that is wrong – or omitted?
    Any help appreciated.
    Cheers
    Neil
    As I can see through Firebug, the flash belongs to div named “ja-toppanel” which has z-index=700. While banner in div “ja-header” has z-index=600, so that the flash will cover the banner. Please set z-index of ja-header greater than 700 if you wanna it be over the flash.
    Hope this make sense.
    kristobal1969 Friend
    #564228
    I have installed top-pannel on a template from Gavick and I have a problem with the z-index value. Because I am unable to find where to change in toppanel files in order to have the top pannel in front of the menus (when deployed).
    Could you help please ?
    here is the link of the page : http://www.oasisexpress.fr/
    Kris
    Hi Kris,
    By default, we set the ‘z-index: 1000;’ for this top panel. However, the menu in gavick template also has this value so you can open the file: /modules/mod_jatoppanel/assets/css/style.css
    Look for this css rule:
    .ja-toppanel-mainwrap {
    position: absolute;
    padding: 0;
    margin: 0;
    z-index: 1001; <<< change to this value
    width: 100%;
    left: 0;
    #565743
    thanks a lot It works now. Sorry I have not seen your post till today !!
This topic contains 5 replies, has 3 voices, and was last updated by  kristobal1969 9 years, 7 months ago.
