  • glitch Friend
    #140261
    Hi all, i’ve got a problem with my site. It runs on joomla 1.5.9 and virtuemart 1.1.3. Everything is fine after fixing some minor problems except for a bug in the user registration.
    When a new user tries to register everything works but when i log into the admin panel i see that this new user is duplicated. I don’t know why that happens. Can you help me?
    These are two images from the user list and the vm configuration:
    1. prob1
    2. prob2
    Anonymous Moderator
    #301520
    Hi glitch,
    For this issue, please open database, find jos_vm_order_user_info table and empty it.
    chriskirby Friend
    #326016
    Hi where do you locate that folder???
    Arvind Chauhan Moderator
    #326039
    JA Developer;124581Hi glitch,
    For this issue, please open database, find jos_vm_order_user_info table and empty it.[/quote]
    Thats not a folder. Its the Database Table. Use Phpmyadmin to administer your Database. Take backup before you go on.
    Arvind
This topic contains 4 replies, has 4 voices, and was last updated by  Arvind Chauhan 15 years, 1 month ago.
