  • mandig Friend
    #167401
    due to a bad coding of a component that I bought I need to create a new menu module and publish it in mainnav position next to my main menu module.
    Basically the component need to have a public menu link to work correctly but I want to show it only to registered users thus the developer suggested me to create a new menu module, set it as Registered users only and keep the menu link as public.
    My problem is now that the template shows just 1 menu module, the one that I set in the general configuration of the template.
    How can I publish 2 different menu modules in mainnav position ?
    Thanks for the help.
    Manos Moderator
    #406194
    Hi, which joomla version are you referring to ?
    mandig Friend
    #408937
    I’m using Joomla 1.5.23
    Manos Moderator
    #408947
    You can read from here -> http://wiki.joomlart.com/wiki/JA_Template_Framework/FAQs on how you can achieve this!
    Manos
This topic contains 4 replies, has 2 voices, and was last updated by  Manos 13 years, 4 months ago.
