  • jawas Friend
    #158252
    Hello
    I use the template JA_T3_BLANK voila, the editor does not appear in fronend, even any other
    I try with another template that works?
    and how to solve?
    thank you
    ithacaindy Friend
    #369911
    The TinyMCE Editor is buggy beyond belief. I suggest switching to JCE. I had the same problem you are experiencing before switching.
    thuanlq Friend
    #369978
    Hi @jawas,
    Please check css,js compression on your template, try to turn off optimize css, optimize js in template configuration, and make sure “Default WYSIWYG Editor” is “Editor-tinyMCE” in global configuration > site settings.
    If it is not resolved, please provide me your website information, i will check and give you solution.
    thankx
    jawas Friend
    #370016
    <em>@thuanlq 212626 wrote:</em><blockquote>Hi @jawas,
    thankx</blockquote>
    For JCE ,Please check css,js compression on your template, try to turn off optimize js in template configuration and devloppement on ON,
    Bug t3 v2 in compression js
    For low speed site none but not js template compression?
    thankx
    thuanlq Friend
    #370129
    css,js compression to speed up your site, compression has errors when css,js files has some errors or conflict with orther files. For JCE , Please add “tiny_mce_gzip.js” for “Optimize Exclude” param in template configuration page
This topic contains 5 replies, has 3 voices, and was last updated by  thuanlq 13 years, 11 months ago.
