  • atu61206046 Friend
    #1014080
    Hallo liebes Support Team,
    ich benötige eure Hilfe. http://www.rbm1.at
    Bei der Slideshow kann ich die Größe nicht ändern finde auch kein Modul wo ich die Slideshow bearbeiten kann. Ich meine nicht Bilder und Text einfügen, sondern die Größe, ganze Seite Effekte usw.
    Auf der Home sollte das solidres laufen, da komme ich mit den Einstellungen gar nicht hin.
    Solidres gibt es dafür eine deutsche Übersetzung?
    Danke für eure Hilfe
    LG Albert
    Pankaj Sharma Moderator
    #1014102
    Could you please write the question in the English language. I am not able to understand your native languages.
    If you have the issue with slideshow creation kindly follow this documentation.
    atu61206046 Friend
    #1014104
    Hello dear support team,
    I need your help. http://www.rbm1.at
    In the Slideshow I can not change the size synonymous find no module where I can edit the slideshow. I do not mean to insert pictures and text, but the size, all page effects, etc.
    On the start should run the Solidres, since I do not go with the settings.
    Solidres is a German translation?
    thanks for your help
    LG Albert
    #1014131
    For slideshow it use tge same image that you will use in the JA ACM module.
    If you want to show the slideshow as showing in demo site kindly follow the documentation link i sent in last post to configure it.
    For solider please open a separate thread with issue details and subject.
This topic contains 3 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 10 months ago.
