  • dreamkissed Friend
    #178617
    This is a fresh installation of Joomla 2.5. I installed Puresite and the accompanying extensions with no problem, but now I’m having a couple major problems configuring it:
    1) Content is not appearing. I have set up a featured article to show on the home page, and a 2nd item in the main menu. Neither appears when the Puresite template is default, but he content does display when standard Atomic/Beez Joomla templates are default.
    2) Logo appearance. This one’s partly my mistake — the logo is square, so I messed with the CSS height. Oops. I tried uninstalling and reinstalling the template to reset everything back to the original, but the height in the blue style (not default-blue) is still messed up. I’d like to revert everything to the original, but can’t see how. Also, is there any way to display a larger (taller) logo in this template? I’ve set it to a text logo for now, but I’m not really happy with that.
    Thanks for your help. It’s great that there’s a responsive template for J2.5 available.
    #459279
    Hi dreamkissed,
    1) It’s a caching issue, i disabled caching in the template back-end and now you can see the fresh site.
    2) If you want to replace the image logo by your own logo with a different size you can try to follow my post here, I hope it help !
    dreamkissed Friend
    #459770
    Thank you very much!
This topic contains 3 replies, has 2 voices, and was last updated by  dreamkissed 12 years, 5 months ago.
