test melih
 melih
  • Aratype Friend
    #203175
    Dear all,
    I installed the template and I have 3 problems:
    1. I changed the color to “turquoise” and it only appears in the internal pages not in the main page!
    2. I added Bosnian and Arabic languages to English. I put Bosnian as a default but it does not appear in the website.
    3. I do not have the language switcher icon on the main page although I activated it in the back-end
    I hope that you can help me on that…
    Thanking you in advance,
    Best regards,
    Ara
    By the way, Installing the multilingual files upon template’s installation was not successful (many time) as it caused that the sample data does not work. I installed the English version first and then added other languages afterward.
    1) Your home menu item is using the features-intro layout so you should edit that layout and in theme settings assign the turquoise theme to it as i have already done for your home now
    2) You should create new menus ( Bosnian and Arabic ) then make 2 new templates ( Medicare-Bn – Medicare-Ar )and assign to every new template inside navigation tab the respective language menu and then assign this template to the respective menu items , this will solve also your point 3
    Aratype Friend
    #557076
    Hi Pavit,
    Thank you! Could you explain more or could you give the links that explain all that as it is not clear to me.
    Thanking you in advance.
    Best
    Ara
    Hi @aratype
    From what i can see on your website seems that you solved it , You have a multilanguage installed
This topic contains 4 replies, has 2 voices, and was last updated by  pavit 10 years, 1 month ago.
