  • Andrew Winkler Friend
    #190184
    I run Joomla 2.5.14 with JA Wall. I’ve recently updated my JA Wall template plus all the JA supplied extension to the latest version using the JAEM. Everything seem to fine at first, but today, after changing the length of the modules, the modules suddenly have a 7-8mm padding around them and a grey border, in spite of the fact that the colour selected for the border in the module settings is white. When I went back into the module I discovered that there is no longer a field for the module suffix, making it impossible for me to enter the no padding parameter to get rid of the padding.
    #504176
    I rolled back both modules to the previous version with the result that the module suffix fields reappeared in the module settings. Unfortunately, after re-entering the ‘ no-padding’ parameters, the padding did NOT go away, so I checked whether the customisation in the template.css for the no-padding suffix setting got lost in the template upgrade but the code is still there.
    [PHP]
    .no-padding .box-ct { padding: 0 !important; }[/PHP]
    #504177
    Sorry, I fixed it myself. The problem was that when entering the ‘ no-padding’ suffix, with the space in front, the space for some reason went away with the result that the parameter didn’t work. It’s fine now, except that i’m forced to use the old version of the modules. It would be good if you guys could bring back the suffix parameter field in the next version of the two facebook modules.
This topic contains 3 replies, has 1 voice, and was last updated by  Andrew Winkler 11 years, 2 months ago.
