Viewing 6 posts - 16 through 21 (of 21 total)
  • mpinchuk Friend
    #457846
    1) JA tabs don’t display anything now :(( in IE
    2) When you go to page, for example, http:///kniga-retseptov.html the main content of this page on K2, but it is displayed correctly in IE. Why it doesn’t displayed correctly on the fron-page http:// in IE???
    And there are also a lot of script errors appeared when the page is downloaded in IE!
    mpinchuk Friend
    #457873
    JA Tabs don’t work correctly also in another brawsers.
    When I click on url from first tab it shows me the articl from the second tab!!!
    Ninja Lead Moderator
    #457943
    There are screenshots from your site i saw JA Tab is fine. I tested on our system and could not found the error as mentioned.
    And about error on K2 Homepage (IE browser) on your site, because Ja Anion template could not support K2 and css is not styled for this case. However, i helped you to get it fixed.
    Open <blockquote>components/com_k2/css/k2.css</blockquote>
    and add
    .k2ItemsBlock ul li table table {width: 100%; }
    1. tab1
    2. tab2
    mpinchuk Friend
    #458030
    Hello!
    Thank you very much for css correction for IE.
    But with tabs I explained not correct.
    I have got the same url links (for example) for first article in the first and the second tabs, look at the pictures please:
    1) Mouse pointed at the first picture:
    the url of article is /kniga-retseptov/miaso/bluda-iz-farsha/farshirovanniy-perets.html
    2) Mouse pointed at the second picture:
    and again we got url /kniga-retseptov/miaso/bluda-iz-farsha/farshirovanniy-perets.html
    I told about that. (((
    1. Photo1
    2. photo2
    #458197
    I lose entirely my time checked and found error on your site. You are mistake format on JA Tabs plugin
    from
    <blockquote><p>{jatabs type=”modules” animType=”animNone” style=”anion” position=”top” widthTabs=”120″ heightTabs=”30″ width=”100%” height=”auto”mouseType=”click” animType=”animFade” colors=”10″ module=”ja-tabs” }{/jatabs}</p></blockquote>
    change to
    <blockquote><p>{jatabs type=”modules” animType=”animNone” style=”anion” position=”top” widthTabs=”120″ heightTabs=”30″ width=”100%” height=”auto”mouseType=”click” colors=”10″ module=”ja-tabs” }{/jatabs}</p></blockquote>
    I helped you fix it, please your site again.
    mpinchuk Friend
    #458199
    Thank you very much for help, and sorry for your wasted time.
    It works now, thank you!!!
This topic contains 21 replies, has 3 voices, and was last updated by  mpinchuk 12 years, 6 months ago.
