April 26, 2016 at 10:48 am #922908
from some days the mobile layout of my website have two problems, even if I didn’t do any change:- when you open the menu you will see two cross instead of one
- when you are in some pages the header is not displayed and everything look white, so navigation is no longer possible.
This happen both for android and ios mobiles. What happened?
I am attaching here the screenshots to show you exacltly the problem.
Please advise, thanks
Saguaros ModeratorSaguaros
April 27, 2016 at 3:57 pm #923555Ok, it worked, thank you.
What about the second problem? I see two crosses in the mobile menu (please see screenshot). In the demo there is a layer that partially cover the second cross, but not in my site. Please advise.
Thank you
April 28, 2016 at 4:42 am #923807Try adding this css rule into above ‘custom.css’ file:
@media (max-width: 360px) { .off-canvas-open .t3-header .btn.btn-menu.off-canvas-toggle { display: none; } }
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 3 replies, has 2 voices, and was last updated by Saguaros 8 years, 6 months ago.
