TomC Moderator
TomC
- October 2014
- 3155 times in 2495 posts
June 19, 2015 at 9:11 pm #739880Make the first suggestions – and (temporarily) leave the home page video issue alone (i.e. with the space created). I’d like to see what’s going on and see if I can assist further.
Tech-xml FriendTech-xml
- October 2010
- 5 times in 2 posts
- October 2010
- October 2010
TomC ModeratorTomC
- October 2014
TomC ModeratorTomC
- October 2014
TomC ModeratorTomC
- October 2014
- October 2010
June 19, 2015 at 11:01 pm #574880<em>@TomC 479183 wrote:</em><blockquote>Try This . . ..
Within file path –> /components/com_kunena/template/blue_eagle/css/kunena.forum-min.css
at line 1, modify as follows:
#Kunena {
line-height: 1.333em;
margin: 0;
padding-top: 50px;
}You can, of course, play around with the pixel value for the “padding-top” property until you arrive at the result you’re most happy with.
Hope That Helps.</blockquote>
@tomc sorry, had it wrong, just let this modification
- October 2010
June 19, 2015 at 11:01 pm #641224<em>@TomC 479183 wrote:</em><blockquote>Try This . . ..
#Kunena {
margin: 0;
padding-top: 50px;
- October 2010
June 19, 2015 at 11:01 pm #739888<em>@TomC 479183 wrote:</em><blockquote>Try This . . ..
#Kunena {
margin: 0;
padding-top: 50px;
- October 2010
Adam M ModeratorAdam M
- May 2014
- 1271 times in 1235 posts
June 24, 2015 at 10:59 am #575366Hi @insofticursos,
Could you please clarify a little bit about the problem you’re getting with or provide a screenshot indicate the problem so I can assist you better ?
- May 2014
June 24, 2015 at 10:59 am #641696Hi @insofticursos,
- May 2014
June 24, 2015 at 10:59 am #740358Hi @insofticursos,
- October 2010
June 27, 2015 at 3:18 am #575675@adam M Some components have problems in the header section. The height of this misfit:
That link is possible to see the problem: http://goo.gl/yGYe8b
This topic contains 47 replies, has 3 voices, and was last updated by Tech-xml 9 years, 3 months ago.
