Tech-xml Friend
Tech-xml
- October 2010
- 5 times in 2 posts
Adam M ModeratorAdam M
- May 2014
- 1271 times in 1235 posts
June 29, 2015 at 5:37 pm #575829Hi @insofticursos,
Sorry for the delay in getting back to you. Please provide a temporary admin account via private reply since I have to login in order to see the link you provide.
Tech-xml FriendTech-xml
- October 2010
- May 2014
June 30, 2015 at 3:14 pm #575919Hi @insofticursos,
Thanks for the info but when I try to access this link http://goo.gl/yGYe8b with the temporary admin account, I got this error message “Voc? n?o est? autorizado a visualizar este recurso“.
- May 2014
June 30, 2015 at 3:14 pm #642248Hi @insofticursos,
- May 2014
June 30, 2015 at 3:14 pm #740908Hi @insofticursos,
- October 2010
- October 2010
- October 2010
- October 2010
- May 2014
July 2, 2015 at 4:58 am #576088Hi @insofticursos,
Sorry for the delay in getting back to you. I have checked this part and see that you modified the template and assign module position “left-menu” there (where you put the module with Login button).
There’s 1 module named “Login Usu?rio” in module position “left-menu” with access level set to Guest and module “Sair“, please recheck.
- October 2010
- October 2010
- October 2010
- May 2014
July 3, 2015 at 7:34 am #576223Hi @insofticursos,
Look like you misunderstood my answer. I mean currently, there are 2 modules in position “left-menu” and one of them is set with access level “Guest“.
After you logged in with Guest account, the 2nd module is displayed right below the Login button because there’s not enough space there.
Could you please clarify a little bit about your desire result so I can assist you better ?
This topic contains 47 replies, has 3 voices, and was last updated by Tech-xml 9 years, 3 months ago.
