Tech-xml Friend
Tech-xml
- October 2010
- 5 times in 2 posts
July 3, 2015 at 12:03 pm #576296@adam M That’s not the problem, I think you got lost in my question by the time, and other people have started to answer before.
For now let’s forget the problma access and module position.
The main problem is the upper spacing that is happening in Some places of my site.
The attachments explain and problem easy way to understand
That link is possible to see the problem: http://goo.gl/yGYe8b
- Adam M Moderator
Adam M
- May 2014
- 1271 times in 1235 posts
July 6, 2015 at 4:36 am #576425Hi @insofticursos,
1. Please navigate to admin >>> Menus >>> Membros >>> Login
* Switch to tab Options >>> Login Description Text : this is where you put your description text
* Switch to tab Page Display >>> Page Heading : this is where you put your heading
2. Please open file /templates/uber/css/custom.css then add this code :
.com_users.view-login #t3-header {
position: static;
}AuthorPostsThis topic contains 47 replies, has 3 voices, and was last updated by Tech-xml 9 years, 3 months ago.
