  • ganesh74 Friend
    #172539
    Hi all,
    I insert a flash animation in the slide position.
    When you save the file and the module does not save it stays white but the template ja erio supports flash?
    Thanks to all
    <blockquote>ja erio supports flash?</blockquote>
    You must insert the correct code in your custom-html module to have the flash showed correctly something like this
    <object height="yourheight" width="yourwidth" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=10,0,32,18" classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000">
    <param name="wmode" value="transparent" />
    <param name="src" value="images/stories/swf/yourfile.swf" /><embed height="yourheight" width="yourwidth" src="images/stories/swf/yourfile.swf" wmode="transparent" type="application/x-shockwave-flash"></embed>
    </object>
    and check if your editor doesn’t clean your html code when you save your module ( in other words after saved the module check if the code inside is still the same you inserted before )
    ganesh74 Friend
    #433003
    the problem is just that, after saving the module the code is deleted that with editor activeted or disabled
    Which editor are you using ?
    ganesh74 Friend
    #433006
    TyniMCE of default…..
    Try to check this
    goto content–article-manager on the up right you will see the Option button click on it and check the text filter tab on the right
    Super Users must have No Filtering
    ganesh74 Friend
    #433010
    Now it’s ok!!!!
    thx a lot:laugh:
This topic contains 7 replies, has 2 voices, and was last updated by  ganesh74 12 years, 11 months ago.
