October 17, 2011 at 8:29 pm #169769
Hello, I installed the template JA Social in my localhost using the quickstart. Also install all plugins, components, but when I try to install a custom file in the: customjomsocial_theme_social_j15.v1.0.3 a message:
Error! Could not find an XML setup file in the package.
What am I doing wrong? If anyone can help me. Thank you.
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
October 17, 2011 at 8:36 pm #419872<em>@unicoba 276577 wrote:</em><blockquote>Hello, I installed the template JA Social in my localhost using the quickstart. Also install all plugins, components, but when I try to install a custom file in the: customjomsocial_theme_social_j15.v1.0.3 a message:
What am I doing wrong? If anyone can help me. Thank you.</blockquote>
Are you saying that you are trying to install the JomSocial component into your JA Social template?October 18, 2011 at 10:24 am #419978Tom thanks for the reply.
I installed the quickstart template for Social Ja but when I view the site do not see the main menu item Joomsocial (hot) equal to demo.
TomC ModeratorTomC
- October 2014
October 19, 2011 at 3:35 am #420117If you do not have the JomSocial component installed, then there will not be a “JomSocial” menu item.
October 19, 2011 at 11:46 am #420193Tom joomsocial should be in the quickstart package jatc_social_j15? Or install the quickstart after I install the file in the folder custom/jomsocial_theme_social_j15.v1.0.3
Tks
TomC ModeratorTomC
- October 2014
October 20, 2011 at 6:25 am #420382<em>@unicoba 276974 wrote:</em><blockquote>Tom joomsocial should be in the quickstart package jatc_social_j15? Or install the quickstart after I install the file in the folder custom/jomsocial_theme_social_j15.v1.0.3
Tks</blockquote>
No, because JomSocial is a 3rd party commercial component. It is NOT part of the JA Social template package.JA SOCIAL is a template designed for use with the JomSocial component. In order to have the JomSocial functionality, you must purchase your license from http://www.jomsocial.com separately, and then install the component into your JA Social template.
This topic contains 6 replies, has 2 voices, and was last updated by TomC 12 years, 11 months ago.
