  • puntje Friend
    #906057
    I have trouble with the layout, see attachments
    1. The sidebar yellow is not scrolling on iPhone and is not aligned in center and not closing on the iPhone
    2. The copyright is not showing all. I miss the line or logo or a part of it
    3. Content-bottom is not aligned wright on the iPhone, it is also on the footer
    4. Can i make different kind of spotlights with there own css. Know they are the same
    5. With tabs can i make a custom html, just a question
    1. side-barnotscrollingoniphoneandnotshowingall
    2. copyright-not-showing-all
    3. contentbottomisshowinginthefooter
    Ninja Lead Moderator
    #906483
    You can find my answer to your request.
    1) It does not work with responsive on the mobile layout because the module id: 137 (custom html module) does not support the responsive layout and you have to make module id: 137 to support responsive layout first
    2) You can create the footer module and assign it to footer position
    3) Please have a look at the screenshot, you will see the text in Content-bottom is forcing align center.
    4) With spotlight postion, you only change the width on that but all css styles and effect are the same.
    5) You can give the screenshot of what you are trying to do.
    1. Screen-Shot-2016-03-30-at-10.44.29
    puntje Friend
    #908675
    #908834
    The problem of your site came from your custom work on your site and you need to fix it as my tweak
    Open templates/ja_moviemax/css/custom.css file
    find and change
    .btn-sidebar.open {
      position: fixed;
      right: 400px;
      top: 0;
      background-color: #ffbf43;
    .t3-big-sidebar > .inner {
        color: #000;
        height: 100vh;
        position: fixed;
        top: 0;
        overflow: none;
        width: 400px;
        padding-left:5px;
        padding-right:5px;
    to
    .btn-sidebar.open {
      position: fixed;
      top: 0;
        color: #000;
        height: 100vh;
        position: fixed;
        top: 0;
        overflow: none;
        padding-left:5px;
        padding-right:5px;
    Hope it helps
    puntje Friend
    #908936
    puntje Friend
    #908954
    puntje Friend
    #909175
    #909708
    Can you give me the link to see that problem on your site? I will help you to check it
    puntje Friend
    #909724
    #909944
    You can use this way to fix this bug
    Open templates/ja_moviemax/css/custom.css file and add the CSS style
    @media  (max-width: 767px) {
        .t3-footer .t3-spotlight {
            display: none !important;
        .t3-footer {
            margin-top: 70px !important;
            margin-bottom: 20px !important;
This topic contains 9 replies, has 2 voices, and was last updated by  Ninja Lead 8 years, 7 months ago.
