December 16, 2009 at 11:05 pm #146902
I have downloaded and installed the JA Kyanite II template. However, when I publish it in my Joomla! 1.15.5, it doesn´t work.
This is the URL where the template is published: http://www.gfpnet.com.br/index.php
Here it is the configuration of the environment. When I publish any other template, it suddenly shows up the website.
PHP Version 4.4.7
System Linux ns1.icontrole14.net 2.6.9-55.0.2.ELsmp #1 SMP Tue Jun 12 17:59:08 EDT 2007 i686
Build Date Sep 27 2008 08:48:23
Configure Command ‘./configure’ ‘–enable-bcmath’ ‘–enable-calendar’ ‘–enable-ftp’ ‘–enable-gd-native-ttf’ ‘–enable-libxml’ ‘–enable-magic-quotes’ ‘–enable-sockets’ ‘–prefix=/usr/local’ ‘–with-apxs=/usr/local/apache/bin/apxs’ ‘–with-curl=/opt/curlssl/’ ‘–with-freetype-dir=/usr’ ‘–with-gd’ ‘–with-imap=/opt/php_with_imap_client/’ ‘–with-imap-ssl=/usr’ ‘–with-jpeg-dir=/usr’ ‘–with-kerberos’ ‘–with-libxml-dir=/opt/xml2/’ ‘–with-mcrypt=/opt/libmcrypt/’ ‘–with-mhash=/opt/mhash/’ ‘–with-mysql=/usr’ ‘–with-mysql-sock=/var/lib/mysql/mysql.sock’ ‘–with-openssl=/usr’ ‘–with-openssl-dir=/usr’ ‘–with-png-dir=/usr’ ‘–with-ttf’ ‘–with-xpm-dir=/usr/X11R6’ ‘–with-zlib’ ‘–with-zlib-dir=/usr’
Server API Apache
Virtual Directory Support disabled
Configuration File (php.ini) Path /usr/local/lib/php.ini
PHP API 20020918
PHP Extension 20020429
Zend Extension 20050606
Debug Build no
Zend Memory Manager enabled
Thread Safety disabled
Registered PHP Streams php, http, ftp, https, ftps, compress.zlibZend logo This program makes use of the Zend Scripting Language Engine:
Zend Engine v1.3.0, Copyright (c) 1998-2004 Zend Technologies with the ionCube PHP Loader v3.1.32, Copyright (c) 2002-2007, by ionCube Ltd.Configuration
PHP Core
Directive Local Value Master Value
allow_call_time_pass_reference On On
allow_url_fopen Off Off
always_populate_raw_post_data Off Off
arg_separator.input & &
arg_separator.output & &
asp_tags Off Off
auto_append_file no value no value
auto_prepend_file no value no value
browscap no value no value
default_charset no value no value
default_mimetype text/html text/html
define_syslog_variables Off Off
disable_classes no value no value
disable_functions no value no value
display_errors On On
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl On On
error_append_string no value no value
error_log error_log error_log
error_prepend_string no value no value
error_reporting 0 2039
expose_php On On
extension_dir /usr/local/lib/php/extensions/no-debug-non-zts-20020429 /usr/local/lib/php/extensions/no-debug-non-zts-20020429
file_uploads On On
gpc_order GPC GPC
highlight.bg #FFFFFF #FFFFFF
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors On On
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
include_path .:/usr/lib/php:/usr/local/lib/php .:/usr/lib/php:/usr/local/lib/php
log_errors On On
log_errors_max_len 1024 1024
magic_quotes_gpc On On
magic_quotes_runtime Off Off
magic_quotes_sybase Off Off
max_execution_time 60 60
max_input_time 30 30
open_basedir /home2/gfpnet:/usr/lib/php:/usr/php4/lib/php:/usr/local/lib/php:/usr/local/php4/lib/php:/tmp no value
output_buffering no value no value
output_handler no value no value
post_max_size 8M 8M
precision 12 12
register_argc_argv On On
register_globals Off On
report_memleaks On On
safe_mode Off Off
safe_mode_exec_dir no value no value
safe_mode_gid Off Off
safe_mode_include_dir no value no value
sendmail_from no value no value
sendmail_path /usr/sbin/sendmail -t -i /usr/sbin/sendmail -t -i
serialize_precision 100 100
short_open_tag On On
SMTP localhost localhost
smtp_port 25 25
sql.safe_mode Off Off
track_errors Off Off
unserialize_callback_func no value no value
upload_max_filesize 2M 2M
upload_tmp_dir no value no value
user_dir no value no value
variables_order EGPCS EGPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
y2k_compliance On Onapache
APACHE_INCLUDE no value
APACHE_TARGET no value
Apache Version Apache/1.3.41 (Unix) PHP/4.4.7 mod_log_bytes/1.2 mod_bwlimited/1.4 mod_auth_passthrough/1.8 FrontPage/5.0.2.2635 mod_ssl/2.8.31 OpenSSL/0.9.7a
Apache Release 10341100
Apache API Version 19990320
Hostname:Port gfpnet.com.br:80
User/Group nobody(99)/99
Max Requests Per Child: 0 – Keep Alive: on – Max Per Connection: 100
Timeouts Connection: 300 – Keep-Alive: 15
Server Root /usr/local/apache
Loaded Modules mod_php4, mod_log_bytes, mod_bwlimited, mod_auth_passthrough, mod_frontpage, mod_ssl, mod_setenvif, mod_so, mod_headers, mod_expires, mod_proxy, mod_auth, mod_access, mod_rewrite, mod_alias, mod_userdir, mod_actions, mod_imap, mod_asis, mod_cgi, mod_dir, mod_autoindex, mod_include, mod_info, mod_status, mod_negotiation, mod_mime, mod_log_config, mod_env, http_coreDirective Local Value Master Value
child_terminate 0 0
engine 1 1
last_modified 0 0
xbithack 0 0Apache Environment
Variable Value
DOCUMENT_ROOT /home2/gfpnet/public_html
HTTP_ACCEPT text/html, application/xhtml+xml, application/xml;q=0.9,*/*;q=0.8
HTTP_ACCEPT_CHARSET ISO-8859-1, utf-8;q=0.7,*;q=0.7
HTTP_ACCEPT_ENCODING gzip, deflate
HTTP_ACCEPT_LANGUAGE pt-br, pt;q=0.8, en-us;q=0.5, en;q=0.3
HTTP_CONNECTION keep-alive
HTTP_COOKIE information=phpinfo; bcf980645e10e63a05d0075b65aff2e0=212bca844cfbbe572250a7e8e1900562
HTTP_HOST gfpnet.com.br
HTTP_KEEP_ALIVE 300
HTTP_REFERER http://gfpnet.com.br/administrator/index.php?option=com_templates&client=0
HTTP_USER_AGENT Mozilla/5.0 (Windows; U; Windows NT 6.1; pt-BR; rv:1.9.1.5) Gecko/20091102 Firefox/3.5.5
PATH /sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin
REMOTE_ADDR 189.38.39.134
REMOTE_PORT 52127
SCRIPT_FILENAME /home2/gfpnet/public_html/administrator/index.php
SERVER_ADDR 70.85.190.42
SERVER_ADMIN webmaster@gfpnet.com.br
SERVER_NAME gfpnet.com.br
SERVER_PORT 80
SERVER_SIGNATURE <ADDRESS>Apache/1.3.41 Server at gfpnet.com.br Port 80</ADDRESS>
SERVER_SOFTWARE Apache/1.3.41 (Unix) PHP/4.4.7 mod_log_bytes/1.2 mod_bwlimited/1.4 mod_auth_passthrough/1.8 FrontPage/5.0.2.2635 mod_ssl/2.8.31 OpenSSL/0.9.7a
GATEWAY_INTERFACE CGI/1.1
SERVER_PROTOCOL HTTP/1.1
REQUEST_METHOD GET
QUERY_STRING option=com_admin&task=sysinfo
REQUEST_URI /administrator/index.php?option=com_admin&task=sysinfo
SCRIPT_NAME /administrator/index.phpHTTP Headers Information
HTTP Request Headers
HTTP Request GET /administrator/index.php?option=com_admin&task=sysinfo HTTP/1.1
Accept text/html, application/xhtml+xml, application/xml;q=0.9,*/*;q=0.8
Accept-Charset ISO-8859-1, utf-8;q=0.7,*;q=0.7
Accept-Encoding gzip, deflate
Accept-Language pt-br, pt;q=0.8, en-us;q=0.5, en;q=0.3
Connection keep-alive
Cookie information=phpinfo; bcf980645e10e63a05d0075b65aff2e0=212bca844cfbbe572250a7e8e1900562
Host gfpnet.com.br
Keep-Alive 300
Referer http://gfpnet.com.br/administrator/index.php?option=com_templates&client=0
User-Agent Mozilla/5.0 (Windows; U; Windows NT 6.1; pt-BR; rv:1.9.1.5) Gecko/20091102 Firefox/3.5.5
HTTP Response Headers
X-Powered-By PHP/4.4.7
P3P CP=”NOI ADM DEV PSAi COM NAV OUR OTRo STP IND DEM”bcmath
BCMath support enabledcalendar
Calendar support enabledctype
ctype functions enabledcurl
CURL support enabled
CURL Information libcurl/7.19.0 OpenSSL/0.9.7a zlib/1.2.1.2 libidn/0.5.6ftp
FTP support enabledgd
GD Support enabled
GD Version bundled (2.0.28 compatible)
FreeType Support enabled
FreeType Linkage with freetype
GIF Read Support enabled
GIF Create Support enabled
JPG Support enabled
PNG Support enabled
WBMP Support enabled
XBM Support enabledimap
IMAP c-Client Version 2004
SSL Support enabled
Kerberos Support enabledmcrypt
mcrypt support enabled
version >= 2.4.x
Supported ciphers cast-128 gost rijndael-128 twofish arcfour cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes
Supported modes cbc cfb ctr ecb ncfb nofb ofb streamDirective Local Value Master Value
mcrypt.algorithms_dir no value no value
mcrypt.modes_dir no value no valuemhash
MHASH support Enabled
MHASH API Version 20060101mysql
MySQL Support enabled
Active Persistent Links 0
Active Links 1
Client API version 4.1.22
MYSQL_MODULE_TYPE external
MYSQL_SOCKET /var/lib/mysql/mysql.sock
MYSQL_INCLUDE -I/usr/include/mysql
MYSQL_LIBS -L/usr/lib -lmysqlclientDirective Local Value Master Value
mysql.allow_persistent Off Off
mysql.connect_timeout 60 60
mysql.default_host no value no value
mysql.default_password no value no value
mysql.default_port no value no value
mysql.default_socket no value no value
mysql.default_user no value no value
mysql.max_links Unlimited Unlimited
mysql.max_persistent Unlimited Unlimited
mysql.trace_mode Off Offopenssl
OpenSSL support enabled
OpenSSL Version OpenSSL 0.9.7a Feb 19 2003overload
User-Space Object Overloading Support enabledpcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 7.0 18-Dec-2006posix
Revision $Revision: 1.51.2.4.2.3 $session
Session Support enabled
Registered save handlers files userDirective Local Value Master Value
session.auto_start Off Off
session.bug_compat_42 On On
session.bug_compat_warn On On
session.cache_expire 180 180
session.cache_limiter none nocache
session.cookie_domain no value no value
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_secure Off Off
session.entropy_file no value no value
session.entropy_length 0 0
session.gc_divisor 100 100
session.gc_maxlifetime 900 1440
session.gc_probability 1 1
session.name bcf980645e10e63a05d0075b65aff2e0 PHPSESSID
session.referer_check no value no value
session.save_handler user files
session.save_path /tmp /tmp
session.serialize_handler php php
session.use_cookies On On
session.use_only_cookies Off Off
session.use_trans_sid Off Offsockets
Sockets Support enabledstandard
Regex Library Bundled library enabled
Dynamic Library Support enabled
Path to sendmail /usr/sbin/sendmail -t -iDirective Local Value Master Value
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
safe_mode_allowed_env_vars PHP_ PHP_
safe_mode_protected_env_vars LD_LIBRARY_PATH LD_LIBRARY_PATH
url_rewriter.tags a=href, area=href, frame=src, input=src, form=,fieldset= a=href, area=href, frame=src, input=src, form=,fieldset=
user_agent no value no valuetokenizer
Tokenizer Support enabledxml
XML Support active
XML Namespace Support active
EXPAT Version 1.95.6zlib
ZLib Support enabled
Compiled Version 1.2.1.2
Linked Version 1.2.1.2Directive Local Value Master Value
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no valueAdditional Modules
Module Name
ionCube LoaderAder.
John Wesley Brett ModeratorJohn Wesley Brett
- July 2013
- 645 times in 426 posts
December 17, 2009 at 5:11 pm #326857You’ve got to get rid of your http://www.gfpnet.com.br[FONT=”Arial Black”]/index.html[/FONT] file. It overrides everything (including the index.php file) in the root directory.
Just back it (the index.html file now showing the GFPNet logo) up…then delete it for a second and you’ll gain a whole new outlook on the world. 🙂 This allows the index.php file to take over.
If you are wanting to put your Joomla site up in the background of your site…base it in a subfolder…not the root.
Have fun!
John. -
This topic contains 2 replies, has 2 voices, and was last updated by John Wesley Brett 14 years, 11 months ago.
