Viewing 15 posts - 1 through 15 (of 17 total)
  • gedasbn25 Friend
    #1049635
    Hey, So I have couple problems:
    1. Logo is not vertically aligned to the middle.
    2. Buttons color change when mouse over ( header and footer ) and not changing font color.
    3. When trying to edit page http://fleetrackpro.com/info-center , it shows blank ( no content block at all ).
    Please investigate these problems. URL: http://fleetrackpro.com/
    P.S. I have a premium subscription but not able to mark topic as a premium, please fix it. Thanks
    • This topic was modified 7 years, 4 months ago by  gedasbn25.
    • This topic was modified 7 years, 4 months ago by  Saguaros.
    You can edit the topic to set it as PREMIUM topic, I just edited for you.
    1) Could you demonstrate of how it should be via screenshot?
    2,3 ) You can share the credentials of your site so I can take a look.
    gedasbn25 Friend
    #1049934
    gedasbn25 Friend
    #1050496
    is it premium support or what?
    Hi Gedas,
    I added this css rule:
    .jub-block .header .navbar-brand.logo-image { padding-top: 5px; }
    into: Settings > Custom Style > Custom Css
    You can also change the value to suit your need.
    Kindly take a look and let me know if you need further helps.
    gedasbn25 Friend
    #1051540
    Thanks! How about the second part of the problem??
    1. Buttons color change when mouse over ( header and footer ) and not changing font color.
      2.When trying to edit page http://fleetrackpro.com/info-center , it shows blank ( no content block at all ).
    You can try to clear browser’s cache and cookies first and when I edit the page, it shows the same as its on frontend.
    For the button color / font, could you send me screenshot highlighting the issue?
    gedasbn25 Friend
    #1051811
    Clearing cache and cookies doesn’t helped, still shows the empty page ( Only header and footer presents).
    For the buttons, please take a look at header buttons ( top right: info center and login) and footer button ( info center ). When moving the pointer on those buttons it changes to the wrong color and do not change font color. All button’s font colors are set to auto.
    Info center button should become white with black font
    Login button should become darker red
    Footer Info center button should also become darker red, and also it has that line under it for no reason. And please check the font color, its set to auto and shows gray font color……
    Please fix it.
    It’s weird, attached screenshot is how it looks when I go to edit mode of homepage.
    1. screenshot-fleetrackpro.com-2017-07-31-20-32-15
    gedasbn25 Friend
    #1052837
    because you are going to the wrong page. Go to fleetrackpro.com -> Info Center ( http://fleetrackpro.com/info-center )
    Hi Gedas,
    I see the issue, let me pass to the developer for further checking, pls stay tuned.
    gedasbn25 Friend
    #1053404
    How about the other problems???????????
    May I know which color for the text you prefer when hovering button (info center)?
    gedasbn25 Friend
    #1054303
    Black, as it suppose to be by default.
    I just added style via template and the text is black when hovering button now.
This topic contains 16 replies, has 2 voices, and was last updated by  Saguaros 7 years, 3 months ago.
