  • turminator Friend
    #172094
    I create a JA Slideshow module and I set to show with images but, now is not appearing anyone. I test to modify permission folder but is not happens any fix solution. Many thanks for all!
    TomC Moderator
    #431025
    The first thing I usually ask/recommend is whether or not you’ve checked/reviewed the [URL=http://www.joomlart.com/forums/topic/userguide-ja-social-template-for-joomla-2-5/”trial-and-error” method I recommend is [URL=http://www.joomlart.com/forums/topic/use-jas-demo-builder-as-a-learning-tool/
    Hi turminator
    Change your source folder to this images/resized/images/stories/slideshow/banner
    Also change your images name in description field
    TomC Moderator
    #431027
    <em>@pavit 290953 wrote:</em><blockquote>Hi turminator
    Also change your images name in description field</blockquote>
    presuming, of course, those elements aren’t already configured correctly
    turminator Friend
    #431079
    Also change your images name in description field </blockquote>
    Hello!
    I do this changes but images continues not appearing. This images are stored in this respective folder. Only I can look text description. Is so strange.
    Many thanks!
    Hi turminator
    It seems very strange
    Try this other solution uninstall your module download the latest version of the ja_slideshow module and install this again
    try if this solve your issue
    turminator Friend
    #431094
    Ok,
    I see it that problem appears when I select Profile and Skin Setting to: social-slideshow in module parameters. That in other hand this is style that will be viewed correctly with JA_SOCIAL template. How can I repair it?
    Many thanks!
    turminator Friend
    #431772
    Is there any new with this problem?
    Many thanks!
    TomC Moderator
    #431804
    <em>@turminator 291911 wrote:</em><blockquote>Is there any new with this problem?
    Many thanks!</blockquote>
    Just out of curiosity, did you ever try the original research suggestions I gave you back within Post #2 in effort to try to research the issue? Just in case you forgot . . .
    JA SOCIAL USER GUIDE
    If you weren’t/aren’t able to find what you need within the User Guide, then the next “trial-and-error” method I recommend is
    using JA’s DEMO BUILDER as a reference and learning tool
    Utilizing these two initial research and compare/contrast tools, let us know if you are able to figure out the issue.
This topic contains 9 replies, has 3 voices, and was last updated by  TomC 13 years ago.
