  • gabriel51 Friend
    #194873
    I am not able to upgrade Joomla from 3.0.3 to 3.1.5 via the Component “Joomla! Update”.
    This componen allways shows: “You already have the latest Joomla! version, 3.0.3.”
    So I did the upgrade manually (uploaded the 3.1.5 update version).
    I found several problems as “Error loading component: com_tags, Component not found”.
    Also my admin menu does not show buttons as “save” or “cancell”.
    Is it possible to upgrade JA Nex to 3.1.5 or 3.2?
    What is the best way to do it?
    Ninja Lead Moderator
    #523148
    I run across on Joomla forum the solution to solve the Joomla 3.0.3 to 3.1.1 upgrade issue here, I’m not sure it can help but please give it a try.
    You should also raise this in the JOOMLA forum, you might get better answers there.
This topic contains 2 replies, has 2 voices, and was last updated by  Ninja Lead 10 years, 10 months ago.
