  • goran17 Friend
    #162937
    I have installed this template on my website and the problem is that when an image has a description (alt tag – i.e. “<img class=”something” src=”/images/stories/pic1.jpg” alt=”photo: someone…” ) the text that should float around the picture goes under the picture.
    Here is an example:
    When there is no description then everything is fine like here:
    _______
    Another problem is, that on the frontpage the title of the article is used as description of the image. Than the whole frontpage looks awful.
    Here is the example:
    Any ideas how to solve the problem?
    Is urgent!
    PS: I had to open the topic here, because I wasn’t able to open it here: http://www.joomlart.com/forums/forum/ja-teline-iii-v2-t3-framework-2/
    Have you got the link to your site, i would like to check css code to find the problem
    goran17 Friend
    #387057
    <em>@tienhc 235027 wrote:</em><blockquote>Have you got the link to your site, i would like to check css code to find the problem
    Thanks</blockquote>
    http://www.fudbalonline.com/
    PS: I solved the problem with the images in the articles, but there is still the problem with the frontpage-images
    goran17 Friend
    #387257
    OK, I solved both problems, but now the names of the modules on the right side are not displayed. (i.e. Latest news, Facebook, ..), only the module itself is shown
    I have put every module – show name on – but no module shows the name..
    what is now the problem?
    goran17 Friend
    #387347
    Could you please try to find out what the problem is? Is very urgent!
This topic contains 5 replies, has 2 voices, and was last updated by  goran17 13 years, 7 months ago.
