  • deancarey Friend
    #121930
    Hi, I’m using Joomla v1.5 and have installed some new templates e.g. Mageia. While I can successfully change the ‘tools’ options in the index.php file, I cannot change the ‘menutype’ options e.g. to suckerfish or transmenu. Regardless of which one I set the site still displays the standard split type menu.
    Should I be setting an option elsewhere in addition to the index.php to get the drop-down menus to appear correctly?
    Any help very welcome!
    Cheers,
    Dean.
    Hieu Nguyen Admin
    #226739
    Hello Dean,
    In this time, JA templates do not compatible with Joomla v1.5, they are in their way upgrading all templates into 1.5. They will have official annoucement when it’s done.
    deancarey Friend
    #226768
    Thanks for reply oceandragon.
This topic contains 3 replies, has 2 voices, and was last updated by  deancarey 17 years, 5 months ago.
