July 10, 2014 at 11:10 am #199570
Today I realized that at the 1024px resolution the text in the second line of the boxes on the left of home page over the main big picture doesn’t appear. Have I to modify some lines of a css? The template should be responsive so I think there is no need doing so. Plase give me a hint. Thanks in advance.
fmfame Friendfmfame
- October 2013
- 25 times in 1 posts
July 10, 2014 at 12:08 pm #541868Thanks for your help but unfortunately it doesn’t seem to work.
fmfame Friendfmfame
- October 2013
July 10, 2014 at 4:27 pm #541887ok then pm me site details so i check it directly in your backend
fmfame Friendfmfame
- October 2013
July 11, 2014 at 10:07 am #541964your backend is very slow. I tried to change css but if i tried to saving the site isnt loading.
Try this:
go to your css folder:
–> go to mod_jaslideshow.css
then look for the line:
@media screen and (max-width: 1199px){
.ja-slidewrap .ja-slide-thumb-inner .thumb-des {
display: none;
}and change that to
display: block;
}let me know..
if this not helping, send me ftp details
July 11, 2014 at 10:17 am #541969Unfortunately this solution doesn’t help.
July 11, 2014 at 10:29 am #541971I have solved the problem canceling a line in the mod_jaslideshow.css file. Now it seems to work fine. Thanks again for your kindness.
This topic contains 8 replies, has 2 voices, and was last updated by fmfame 10 years, 5 months ago.
