vehuel Friend
vehuel
- March 2008
July 7, 2008 at 10:10 am #130537If i try to subscribe an user on my website I receive the following error:
Fatal error: Class ‘JParameter’ not found in /home/u9r70jas/domains/vinicoppadoro.it/public_html/templates/ja_helio/ja_menus/Base.class.php on line 28
Can you help me?
Sherlock FriendSherlock
- 2478 times in 2162 posts
July 8, 2008 at 12:45 pm #258550Hi
Plz edit Base.class.php
Search those lines
function createParameterObject($param, $path='', $type='menu') {
if(defined( '_JEXEC' )) return new JParameter($param, $path);
else return new mosParameters($param, $path, $type);
Change to
//if(defined( '_JEXEC' )) return new JParameter($param, $path);
//else
vehuel Friendvehuel
- March 2008
July 8, 2008 at 1:33 pm #258575Thanks.
if i subscribe an user, there is not error but the page is empty now.
try to subscribe here:
http://www.vinicoppadoro.itvehuel Friendvehuel
- March 2008
July 8, 2008 at 1:54 pm #258578I turn on the debug mode and this is the error:
Notice: Undefined index: path in /home/u9r70jas/domains/vinicoppadoro.it/public_html/templates/ja_helio/ja_templatetools_1.0x.php on line 198vehuel Friendvehuel
- March 2008
July 10, 2008 at 6:37 am #258925i have alwyas the same problem, is there a solution please?
vehuel Friendvehuel
- March 2008
July 10, 2008 at 1:32 pm #259015Acajoom team solved the problem.
thanksSherlock FriendSherlock
July 11, 2008 at 1:37 am #259113Hi vehuel
Can you share what Acajoom temeam did?vehuel Friendvehuel
- March 2008
July 11, 2008 at 6:50 am #259164The template is created to be compatible with Joomla 1.0.x and Joomla 1.5.
Acajoom defined some constant to be as well compatible with both versions of Joomla and that created conflicts. -
This topic contains 8 replies, has 2 voices, and was last updated by vehuel 16 years, 6 months ago.
