Tech-xml Friend
Tech-xml
- October 2010
- 5 times in 2 posts
June 2, 2015 at 9:53 am #206822Created 4 tabs groups, only one of them will use the button link field. The problem is that to remove the links of the other TABs they are still appearing a square.
June 3, 2015 at 5:14 pm #572781Hi
I just check the source code of this acm type but it does have condition to check whether have links or not before showing that box.
Are you using the latest version?
Viewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by Saguaros 9 years, 6 months ago.
