yandi12950@yahoo.com Friend
- February 2016
July 20, 2016 at 9:00 am #951702Hi,
Earlier today I encountered a problem with the article editor. The screenshot shows what I got when I chose any article to be editted. None of the button can be clicked, not close, save, save and close nor toggle editor. I can even navigate away from the page unless of I edit the address line to http://www.mbapratama.com/administrator/index.php
I am not what happen. Please kindly help.
Kind regards
yandi12950@yahoo.com Friendyandi12950@yahoo.com
- February 2016
July 20, 2016 at 9:01 am #951704Hi,
Kind regards
July 20, 2016 at 9:53 am #951725Hi
its issue in your Joomla , you can try to clean Joomla and browser cache .
Also go to extension > Manage > Database > FIX if any erorr there .
This issue mostly come after Joomla update .yandi12950@yahoo.com Friendyandi12950@yahoo.com
- February 2016
July 21, 2016 at 3:55 am #951941Hi,
Thank you for your response.
I have tried clearing joomla expired cache, browser cache and fixing databases errors (under Extension). But none have solved the problem.
I appreciate any other suggestions. Thank you
July 21, 2016 at 4:09 am #951943Hi
I do not know what step u did and this issue comes , if you updated Joomla , then there can be an issue in an update , you can take backup of the site and update Joomla manually again .
Also, post the issue on Joomla forum , so you will get a better answer on this .AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 4 replies, has 2 voices, and was last updated by Pankaj Sharma 8 years, 4 months ago.
Problems with Article Editor
