test melih
 melih
  • ired Friend
    #142475
    I am trying to edit the article index inside a article but I can’t find where to edit it?
    What I want to do is make them into Brief, Features, Specification
    I don’t have a live site yet.
    http://i532.photobucket.com/albums/ee321/mastermdr/Picture1-3.jpg
    ired Friend
    #309988
    Can anyone help?
    scotty Friend
    #309996
    Hi Ired,
    Open the article in your article editor and click the ‘HTML’ button in the editor (the one to the left of the binoculars icon). This will open a new window showing the HTML for your article. If you read through your HTML you will see a line like…
    <hr title=”Components” class=”system-pagebreak”>
    It is what is entered as ‘title’ that you want to change. If you want to create new ones click the ‘pagebreak’ button below the editor and you will be asked for the title you wish to use.
    ired Friend
    #310004
    Thanks scotty, very helpful.
This topic contains 4 replies, has 2 voices, and was last updated by  ired 15 years, 7 months ago.
