gemac Friend
gemac
- March 2007
July 25, 2013 at 3:42 pm #189225I created a site from DEMO of JA Brisk but my footer navigation looks wired, not like in demo,
Instead to be on line, 1 link after another they are 1 link under another, center or left aligned .
http://cyber-cup.ro/gardentest
Can you help me pls.
gemac Friendgemac
- March 2007
July 25, 2013 at 4:40 pm #500159Also i cant make featured articles to appear on home page.
- November 2014
- 3854 times in 3563 posts
July 26, 2013 at 4:34 am #500190Hi
The footer navigation looks wired since it seems that Footer menu module is being assigned to wrong position, as our demo site, it’s assigned to footnav position instead of navhelper. Try to change it again.
For featured articles showing on homepage. Here is configuration:
+ Menu site
+ Article Manger
I tried to help your fix directly on your site but i could not access back-end on your site with information your included on the thread.
gemac Friend
gemac
- March 2007
July 30, 2013 at 12:59 pm #500609For front -end I had same settings problem was I had o leading articles and also 0 intro articles, I put 1 at leading articles, problem solved. Idea come just after saw ypur settings.
Thx
gemac Friendgemac
- March 2007
July 30, 2013 at 1:06 pm #500610Regarding menus on bottom I assigned both to FOOTNAV position but links still arranged one after another not vertically not horizontally.
BTW: I have tried all combinations …be4 asking for help on forum.Ninja Lead ModeratorNinja Lead
- November 2014
July 31, 2013 at 5:14 am #500705Yes, featured articles in home page need to set
<blockquote># Leading Articles 0
# Intro Articles 1
# Columns 1
# Links 0</blockquote>or
<blockquote># Leading Articles 1
# Intro Articles 0
# Columns 1
# Links 0</blockquote>About problem the footer page, I helped you fix directly on your site. Please check it again, let me know if it helps
gemac Friendgemac
- March 2007
July 31, 2013 at 12:18 pm #500756Yes is perfect, but I would like to know what you have done so in the future I can do it myself.
Also I have a problem with modules in positions: postion 20, 21, 22, 23. I have set them to show on all pages but they don’t.
Can you help me with its matter ?
Thank you
PS Actually i find that these positions are not set on template now, but can’t find a way to put them back …:(
- November 2014
August 1, 2013 at 4:23 am #500822This is my solution to solved the problem on footer page
Go to Admin site -> Extensions -> Module Manager -> Open Main Menu and Footer Menu -> in Advance tabs add ja-footnav css class
From link on your site: http://cyber-cup.ro/gardentest/?tp=1 i saw JA Brisk Template default doesn’t support position 20, 21, 22, 23, you can assign module with position 6 to 12.
gemac Friendgemac
- March 2007
August 1, 2013 at 8:30 am #500852I solved the problem adding the postions again in template on :
ja_brisk/tpls/default.php
I added the line:
<?php $this->loadBlock (‘spotlight-6’) ?>
Thank you for your support …
Viewing 9 posts - 1 through 9 (of 9 total)This topic contains 9 replies, has 2 voices, and was last updated by gemac 11 years, 4 months ago.
