vehuel Friend
vehuel
- March 2008
July 4, 2008 at 3:23 pm #130457look at here:
http://www.vinicoppadoro.it/it/prodotti/linea-distribuzione.htmlPathway doesn’t appear in the background h3-bg-hilite.gif
can you help me?
Sherlock FriendSherlock
- 2478 times in 2162 posts
July 5, 2008 at 3:01 am #258034Hi vehuel !
I have looked into your site , i still see pathway in h3. Have you fixed the problem ?vehuel Friendvehuel
- March 2008
July 5, 2008 at 2:30 pm #258072It works in the home page. It doesn’t work if you click in the mod_janewsmoo on the right side of home page.
Look at here: http://www.vinicoppadoro.it/it/prodotti/linea-distribuzione.html
Thanks.Sherlock FriendSherlock
July 7, 2008 at 2:55 am #258237Hi vehuel !
– Please go to admin >> extensions >> module manager >> breadcrumb
– On bottom of breadcrumb page , you set for it display all page.vehuel Friendvehuel
- March 2008
July 7, 2008 at 7:12 am #258274I use joomla 1.0.15, i have not a breadcrumb module.
ThanksSherlock FriendSherlock
July 7, 2008 at 8:13 am #258285Hi vehuel !
I have got the probem , this is a problem in newsmoo module , JA Developer is working with it .
thanks you for report.Sherlock FriendSherlock
July 7, 2008 at 9:54 am #258311Hi vehuel !
You can fix the problem following way below :
– Download attachment file and extract it
– Copy and overwrite to modules folder
Note : Don’t forget backup old file .vehuel Friendvehuel
- March 2008
July 7, 2008 at 10:18 am #258316Thanks.
Why in the pathway the page is only Home?
http://www.vinicoppadoro.it/index.php?option=com_content&task=view&id=18&Itemid=1
vehuel Friendvehuel
- March 2008
July 7, 2008 at 2:55 pm #258357however if i use ARTIO JOM SEF module pathway is not visible.
July 8, 2008 at 1:50 am #258471Hi vehuel !
The pathway only Home because : there isn’t Menu link to that content , You must create a menu , then link it to section or category which stores that content. You can send admin info via pm, i will check it for you. -
This topic contains 10 replies, has 2 voices, and was last updated by Sherlock 16 years, 6 months ago.
