  • Scott Ackerman Friend
    #125566
    It seems as if the breadcrumb function fails to operate correctly if you don’t have an article of content in a category or subcategory that is part of a menu item. Also when an article is not part of a category that is in a menu item the .contentheading in the CSS file is not applied properly.
    browse to this URL:
    http://www.bltec.org/content/blogcategory/35/12/
    then click on the link labeled “Cole, et al” at the end of the first paragraph. You will end up at this URL:
    http://www.bltec.org/content/view/15/3/
    the breadcrumb path changed to reflect a section that you are not currently in. Also the title on the page is not being formatted properly.
    Khanh Le Moderator
    #239211
    The template just shows what the breadcrumbs module generate; therefore, if you think that there’s problems with your breadcrumb, you should ask some help from Joomla forums.
    For the .contentheading style, I cannot find any page whose the title is not formatted.
This topic contains 2 replies, has 2 voices, and was last updated by  Khanh Le 16 years, 9 months ago.
