October 3, 2014 at 9:44 am #201802
HI!
I have a bilingual site and the problem is that everyday I find that one of the two template styles (English or Spanish) suddenly does not display correctly. Everything seems to be out of place.
This issue is solved every time I clear the cache.
I am using joomla 3.2 and T3v2.
I have the development mode in the template T3 options enabled.
Any idea?
Adam M ModeratorAdam M
- May 2014
- 1271 times in 1235 posts
October 6, 2014 at 5:24 pm #552004HI!
Yes, I am attaching two captures of when the problem appears.
I have disable the plugin: System cache and the problem persists
Thanks a lot!
Adam M Moderator
Adam M
- May 2014
October 7, 2014 at 3:34 am #552056Hi,
Unfortunately, I still couldn’t see the problem. Could you please provide which browser are you using and its version too ?
October 7, 2014 at 12:54 pm #552113It happens in every browser: firefox, google chrome, internet explorer, etc.
The thing is that things get out of place. Please find attached two pictures: one in its normal state and the other when the problem occurs.
They are telling me that I should unable all the cache, but this make the site far too slow… And I dont understand why in any case it should have a problem when cache is enabled.
ANy idea?
Thanks in advanced for your help. 🙂
Adam M Moderator
Adam M
- May 2014
Viewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by Adam M 10 years, 1 month ago.
Problems with cache template not displaying correctly
